PilotPete
- Pete
- May 8, 2023
- Porsche, BMW, M3LR on order
- Chief Pilot
![United-States Country flag](https://www.cybertruckownersclub.com/forum/misc/flags/shiny/32/United-States.png)
Mike,I've never seen sheets of full-hard 304 SS offered on Amazon and there is no way to harden annealed 304 SS to a full-hard temper without multi-ton rollers. If you could provide a link to cold-rolled 304 SS in 3mm thickness, I would be amazed.
The assumption most people have is the Cybertruck alloy will be 304 but, as far as I know, Tesla has never said that. I believe they actually said it's a custom variation on traditional compositions to suit their exact needs. If it's a custom alloy, it would likely be unavailable from any supplier and test results from similar alloys would not necessarily be valid.
What I think is under-appreciated is how much the properties of various alloys of stainless steel can vary, and how dramatically most of them change simply by hardening them with a repetitive cold-rolling process.
I didnāt mean that the CT was 304 SS or that you could find fully hardened 304 on amazon. But rather, if you get a sheet of 3mm 304, and maybe a 5mm sheet, you will see a worse case scenario of how it will look. You will get an idea of the reaction, not a duplication, just an idea. If you can take a 3mm and bounce a .22 20 gr pellet off the skin, then the CT will do at least that and more.
That being said, there are companies out there that have cold rolled 300 series SS available. Might be able to talk them out of a 12āx12ā piece for not too many dollars as a sample. And yes, certainly, the CT is not a 304 SS truck, it is their own 300 series SS (30X) which has (as I understand it) improved corrosion over other 300 series metals.
Dang, now Iām going to actually look for a small piece of hardened 300 series SS today. And I was going to do laundryā¦.
