Delusional
- Phil
- Dec 5, 2019
- Pittsburgh
- F-150
- Construction
![United-States Country flag](https://www.cybertruckownersclub.com/forum/misc/flags/shiny/32/United-States.png)
Since the late 1950's, float glass has been the only way to produce glass if you are aiming for lowest cost in mass production. Float glass is nearly perfectly flat, and it's production speed means the cost is less than half of other methods to produce a windshield, or any other sheet glass.
Tesla's armor glass should be far more resilient than other glass, but will not be completely "bulletproof". There will be times it needs to be replaced. I figured that even though it is of a higher quality than other windshields, CYBRTRK glass may be of a comparable cost to replace, because the flatness makes it easy and cheap to manufacture.
If they curve it, that will make it way, way more expensive than other windshields. It is gigantic, too.
Availability is a factor as well. If it "almost never" breaks.... when you do need one, nobody has one in stock, and you end up waiting weeks to get one, while paying extra.
But this patent produces glass that is curved in small radii at the edges? Is the process similar to blowing glass into a mold like making a bottle? Or dropping hot flat sheets into a mold that only curves the edges? Maybe a robot comes in and bends the corners? Not really understanding exactly what is going on here.
/me goes to read the full patent.
